Badcaps.net Forum
Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting TVs and Video Sources
Register FAQ Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 05-19-2006, 03:55 AM   #1
japlytic
japlytic's Avatar
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
Exclamation A DVD player you should avoid...
At one time, I bought a Panasonic DVD-S35 DVD player from a junkyard. I found something wrong was with the power supply, but I fixed it. The real problem was that the loader tray would not move.
In this model (and its related conterparts), there were two motors on the loader assembly, one of them serving two functions (the transverse motor), which controlled both the tray and the optical assembly slider. Typically, loader assemblies have three motors; one each for the tray, optical assembly slider, and spindle motor.
I think some sort of mechanical problem (which I could not find) has caused a "H-01" error (Tray loading error). Also, I saw a DVD player of the same model on eBay with the same "H-01" error.
Should we avoid this particular model (and its related conuterparts) of DVD player?
__________________
japlytic is offline   Reply With Quote
Old 05-19-2006, 04:40 AM   #2
Rainbow
City & State: Slovakia
Default Re: A DVD player you should avoid...
Test the motor if it's good (disconnect from the controller and use 3V power supply) - this also tests the mechanics - maybe it just needs some grease.
Rainbow is offline   Reply With Quote
Old 05-21-2006, 07:47 PM   #3
japlytic
japlytic's Avatar
I'm a: Hobbyist
The motor is OK, but the mechanics for this motor to operate the tray and the optical assembly slider are somewhat complicated, even though there are no obstructions.
Old 09-08-2006, 01:50 PM   #4
mbates14
no, a DVD player that you should avoid is those stupid KOSS 5-disc surround models. those are the biggest POS machines i have ever seen. firmware corruption and controller failure left and right.
mbates14 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2013
Powered by vBulletin ®
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
