Samsung SyncMaster 2493HM black screen with power
  • thirdoff
    • May 2011
    • 13
    Hello. My Samsung 2493HM will power on but has a black screen.
    Working great for a while, it even sometimes works for a long time but then the screen goes black.
    This is what I do know;
    The Blue LED is solid when this occurs.
    Sometimes while it's black, a clicking/ticking noise will start in no particular pattern. The noise may be coming from the speakers but I cannot tell for sure.
    I have opened the case, inspected the caps and they are not visibly swollen. I know this might still be the issue I just want to move in the right direction.
    I shined a flashlight on the screen and I see no picture/color.
    One of the leads to a speaker cone was broken so I soldered to repair but I do not think this is related. The speakers work at all times.
    Before I start replacing the wrong (or right) parts I was hoping for the shared expertise and experience here to help me in the next direction of troubleshooting and repair.
    Thank you.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung SyncMaster 2493HM black screen with power
    The solid blue led indicates that the power board and logic board are likely to be working okay. When the screen goes black, this suggests something wrong on the inverter board.
    The standard procedure here is to post clear focused pictures of all your boards using the manage attachments functions so the pictures are attached to this forum. Please do not post inline because it slows down the loading of pages.
    After you have posted the pictures using manage attachments, we can suggest test points or see if the caps on the inverter board are known bad series.
    --- begin sig file ---
    --- end sig file ---
    • thirdoff
      • May 2011
      • 13
      Photos Attached
      • PlainBill
        • Feb 2009
        • 7034
        Photos Attached
        The pictures are clear enough to give me a point to check. On the fourth picture (inverter) it appears the third pin from the top is the On/Off control line; the fifth through ninth are ground. Measure the voltage on that line when the backlights have gone off. It should be about 3.3 volts. If it is, you have a 'two seconds to black' problem. I believe replacing the two caps on the inverter would be the first step.
        PlainBill
        • retiredcaps
          • Apr 2010
          • 9271
          I agree.
          Normally, I would go for Panasonic FR/FM, but both are out of stock at digikey so FC would be the next choice at
          http://search.digikey.com/scripts/Dk...name=P10301-ND
          Or you can buy from the badcaps.net store and support this site with
          https://www.badcaps.net/store/produc...roducts_id=114
          • thirdoff
            • May 2011
            • 13
            Thank you. I will set it up where I can power on while open. Or I may just change all the caps. I wanted to be sure as the screen may flicker for several minutes before going out. It also may run and be lit for hours or days before it goes out. It does not go out right after turning on. Once it's out - it seems to stay out for a long time. It does not come on and then turn off after 2 seconds ever.
            • jetadm123
              • 2169
              I would also replace the two yellow Sam Young caps on the inverter board, since that brand is not the most reliable.
              • thirdoff
                • May 2011
                • 13
                Sorry, picture 4 shows both boards and I can generically troubleshoot components but I have no idea the location you refer.
                Sorry, I am ignorant to these monitor's components.
                • thirdoff
                  • May 2011
                  • 13
                  So the invertor board is the one in picture 5? I know what an invertor board looks like in a notebook and that looks most like it?
                  • jetadm123
                    • 2169
                    Yes, pic 5. Two yellow caps, marked NXH 470uf 35V.
                    • thirdoff
                      • May 2011
                      • 13
                      Thank you. I will replace the two caps on the inverter board (470uF 35V).
                      I will use and support this board unless I can find it locally over the weekend or with cheaper shipping. I will read up on your brand recommendation.
                      THANKS AGAIN! (Yes I am shouting because it's exciting to see educated, responsive community support!)
                      I will be back with the results if it will help someone else.
                      • thirdoff
                        • May 2011
                        • 13
                        Replaced the two 470uF 35V CAPS on the invertor board. The ones from digikey were too long but they worked any way. They did not however fix my problem. The screen is black, LED is still solid blue and I still here the clicking/ticking. It hasn't light up at all now but the noise is the same. I will try to record it and attach.
                        • thirdoff
                          • May 2011
                          • 13
                          The backlight just came back on. It is still intermittent like it was. What troubleshooting point is next? Again all the CAPS look great. I will record the sound the next time it goes blank. The sound is consistent and only with the blank screen. Every time I try to record the sounds stops and the monitor works, maybe I found the fix! (not really) ...I'll just set up constant recording and it appears it will work forever not allowing me a chance to record.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            1) Check for poor solder joints on the inverter board.
                            2) I wonder if that clicking sound is arcing? That is, poor ccfl or burnt out wiring to/from the ccfl?
                            edit: See
                            http://s807.photobucket.com/albums/y...klight%20lamp/
                            for example pictures
                            • jetadm123
                              • 2169
                              The large ribbon cable that connects the power board to the logic board, with everything connected and powered on, can you take a voltage reading of every point on that cable connector and post your results?
                              • thirdoff
                                • May 2011
                                • 13
                                The monitors works with no noise and full display when its working.
                                The clicking sounds like it is coming from the bottom right of the monitor. I swear the moment I shut down my recording device, the monitor went blank and started clicking. It is blank again after working for about 24 hours, I see it is in power saving mode ok, but when it wakes up it is blank. I got it recorded! The attached zip file contains a recording of the clicking and an amplified version. I will also get readings on the ribbon cable.
                                • thirdoff
                                  • May 2011
                                  • 13
                                  I should also add this started the night of a storm and a power outage. I do not know if it is related.
                                  • alexanna
                                    • Mar 2010
                                    • 1346
                                    Two seconds to black is just a very general term to describe a problem, it can be a lot quicker than two seconds. On some monitors you may not even be able to see through the dark LCD screen
                                    Have you or can you verify that the backlight on voltage stays at about 3.3V when the lights go out?
                                    PlainBill identified the pin to check.
                                    • thirdoff
                                      • May 2011
                                      • 13
                                      Thank you, I still need to set it up so I can check the test points. I was not clear to where the "pins" were located on the inverter. On the white/blue cable or ???...
                                      I was originally hoping just switching the caps would help. Does the noise reveal anything?
                                      • pumady
                                        • May 2011
                                        • 2
                                        Hi thirdoff, do you get the solution? My 2493HM monitor has the same problem, looking forward your suggestion.
                                        • HTR-Informatique
                                          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                          by HTR-Informatique
                                          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                          I also changed the screen because the PC fell and the screen was broken.
                                          I changed the battery with a new and original battery.
                                          I also had corrosion/oxidation on the...
                                          02-09-2025, 06:51 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • totof
                                          Samsung UE50KU6070 black screen
                                          by totof
                                          I have my TV model UE50KU6070 which I am trying to repair.
                                          BN41-02528A / BN94-10800C motherboard.
                                          If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
                                          When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
                                          After one minute the consumption drops to 0W and the TV can turn on with the remote control but...
                                          09-26-2022, 02:34 PM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
