CapXon, CapXon, CapXon!
  • iKitsune
    • May 2010
    • 61
    I've rescued no fewer than 4 LCD TVs of various East Asian makes from CapXon caps. Only done two when I had my camera handy, however.
    First one was an "Akai" 27" 720p.
    Yuuuuck. >.<
    I really loved whoever designed that PSU - the caps right under the heatsink were a JOY to remove. An even LARGER joy to reinstall.
    Recapped it with what I had to hand - yes, I know the ESR is all wrong, etc, I will redo it properly later. I was just practicing, as this was a "throwaway" project and my first re-cap.
    Next TV was an Olevia 42". I got this one from a friend, he said it just stopped working one day.
    Surprise!
    Currently in the process of recapping this one for the second time around, I had it completely reassembled and was looking at my invoice from Newark when I noticed that the 3 1000 uF / 35v caps I got were rated only 85c. I'm going to take pics when it's finished and pretty, and not showing 3 Rubycons being slowly cooked to death.
  • japlytic
    • Oct 2005
    • 2086
    Re: CapXon, CapXon, CapXon!
    Welcome to the forums, iKitsune!
    I'm glad that the repairs are going well.
    In the picture of the first TV power supply that you are repairing, what is the brand and series of the replacement electrolytics marked "(M) 35V"?
    Inside flat-panel TVs, they can get very hot inside... in the Akai power supply, the CapXon KF series were not rated for this application.
    In switching power supplies, I always recommend 105C units in all sections.
    • Scenic
      o.O
      • Sep 2007
      • 2642
      They look like EPCOS
      • Agent24
        I see dead caps
        • Oct 2007
        • 4953
        • New Zealand
        These companies spend good money on a 42" LCD panel and yet don't want to spend an extra few dollars on decent capacitors in the PSU (which is the most critical part)
        It makes me angry!
        -David VanHorn
        • iKitsune
          • May 2010
          • 61
          I think they are EPCOS. The Akai was purchased as "dead unit, intact panel" from a local electronics recycling place. I'm intending on eventually redoing both of these with the appropriate Rubycon and/or United Chemicon caps, rather than just whatever I have to hand that matches the ratings. Before I went and spent money on them, I wanted to make sure the rest of the unit worked.
          I wouldn't put anything less than 105c caps in a PSU under any circumstances.
          • iKitsune
            • May 2010
            • 61
            It makes me angry!
            I know, right? The 42" was a $1300 TV when it was new, too, and it had the same CapXons as a $399 Akai.
            • iKitsune
              • May 2010
              • 61
              OK, another day, more f***ing CapXons. Got a 19" ViewSonic VX1962. Symptoms are backlight dies after ~3 seconds. Lamps test fine on another inverter I've got around. So I pulled the little inverter/power section apart.
              Oooops.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                CapXon are LAME LAME LAME !
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4953
                  • New Zealand
                  I'd argue they're worse than that.
                  -David VanHorn
                  • amayii
                    • Nov 2016
                    • 3
                    • Belgium
                    Found this topic when having a look at a "black screen" on a Viewsonic N4060w.
                    I'm not a professional electronic engineer of any kind however it seems pretty easy to do a recap.
                    I've ordered replacement caps. Here is overview of the board before fixing.
                    I'm planning on replacing these 11 caps.
                    Fingers crossed
                    • amayii
                      • Nov 2016
                      • 3
                      • Belgium
                      Viewsonic N4060w saved with a few cheap caps.
                      Going to be used as occasional entertainment in basement. Not that bad for my first recap
                      • televizora
                        ghettomodmaster
                        • Nov 2016
                        • 957
                        • Bulgaria
                        Excuse me, where I can buy new CapXon-s? I want to recap my TV
                        Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                        1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4953
                          • New Zealand
                          Aliexpress, perhaps? Though they might not be genuine CapXon, maybe re-sleeved Fuhjyyu. Still just as good though.
                          -David VanHorn
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            • televizora
                              ghettomodmaster
                              • Nov 2016
                              • 957
                              • Bulgaria
                              Why BadCaps doesn't supply the users with so needed CapXons?
                              I really, really need authentic CapXon-s!
                                • 31020
                                i'm sure some of us could sell you some cheap "refurbished" ones.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Ive got alot of all values, £4 a cap as quite rare to find working
                                  • televizora
                                    ghettomodmaster
                                    • Nov 2016
                                    • 957
                                    • Bulgaria
                                    There are things, that can be done only with CapXon-s! Like blowing PSU-s, for example you want to make bomb(?) - just stick C4 on some PSU with CapXons. Perfect detonator. Works flawless. By choosing the correct series of the CapXon brand you can even choose the time for detonation with high precision..
                                      • 31020
                                      10 years from now, AudioPhiles will be re-sleeving rubycon & panasonic caps with old capxon sleeves to "keep it looking original"
                                      • jiroy
                                        • Jun 2016
                                        • 2416
                                        • Lebanon
                                        Finished repairing a LG Flatron W1943S , and the culprit is one orphan 1000mf 10v , which kept it in stand by . It's a Sus'con a cousin of capXon it seems , lol ..
                                        • Dannyx
                                          How I "fixed" the display on an Akai LT-3220AD TV
                                          by Dannyx
                                          Good day folks. I thought I'd share with you something I did today, just for a laugh and for a bit of a discussion, since I'm still not entirely convinced what happened there.
                                          I found an Akai LT-3220AD TV in the dumpster - literally - so me and my colleague brought it back into the shop and dusted it off a bit to see if someone maybe gave up too soon.
                                          Long story short: backlight came on but had no picture. My colleague attempted to reprogram the SPI chip but it didn't change anything, so we concluded it must be the panel that's faulty, especially after reading about it...
                                          01-29-2024, 10:12 AM
                                          KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                          by momaka
                                          For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                          http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                          I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                          What mostly drew me into buying it is its 2x PCI-E power connectors...
                                          03-29-2022, 11:34 PM
                                        • Genaugmen
                                          Akai MPK 261
                                          by Genaugmen
                                          I got this akai MPK 261. Had no power from USB. Optional Power adapter caused some light smoking, so unplugged and disassemble to get to the main board. There are two surface mount inductors near the power input. One look obviously damaged, removed both for replacement. Then there's this IC a few components away (pictured) that I can't identify. I've done plenty of plenty of surface mount component work, so replacing it isn't a problem. Any insight into what this could be would be greatly appreciated....
                                          09-17-2023, 01:17 PM
                                        • sumilumi
                                          700mv ripple on Akai Sampler linear supply
                                          by sumilumi
                                          Hi fellow troubleshooters. This is my first post on badcaps. I've recently setup an electronics workbench. i'm also building a studio with old equipment bought faulty at low cost.
                                          I've been into electronics since the mid 80's and particularly in the last few years though only getting hands on with repairs now. My knowledge gaps are significant so I'll be posting here to seek guidance advice and general practical applied learning.
                                          On my bench today is an old ca. 1993-95 Akai hardware sampler. This runs on both a linear and Smps supply. Both are getting on in age and ripple...
                                          01-02-2022, 10:12 AM
                                        • withalligators
                                          Looking for best replacements for Capxons, but can't find data sheets
                                          by withalligators
                                          Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
                                          1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
                                          1 x Capxon 1000uf35v...
                                          03-25-2022, 02:30 PM
