Hi all, last week I jumped into a thread I thought was for my TV model but it turns out the board in question was a different part number. I was asked to provide the pictures of my board in my own thread so here goes.
My TV will not turn on, when I push power button or use remote nothing happens, no error code no blinking lights. I took the back cover off and found the main fuse had blown, tried replacing it and as soon as I plugged it back in the new fuse blew again. Following the previous thread I tested the bridge rectifier and it did not pass the test. Using a multimeter on OHM setting I tested points one and 2 on the rectifier and with the leads one way I got no reading and when reversed i got a reading. On points 3 and 4 i get a reading both way the multimeter leads are connected. Are there any other things that I should check or would the bridge rectifier be enough to cause the main fuse to blow? I have attached pictures of both the front and back of the board and the part number.
Any assistance is greatly appreciated
Paul
Paul
