52" philips tv
    52" philips tv
    I am try to find a t con board for my 52pfl5704d/f7 part #cpwbx4107tpza does anybody have any leads
    Re: 52" philips tv
    is there anybody out there
      Re: 52" philips tv
      http://produto.mercadolivre.com.br/M...2pfl5704df-_JM that board? most are out of stock! these guys have 2.
        Re: 52" philips tv
        Thanks tj for the info but by the time i found out how to read portuguese i missed the sell. I did found a t con board at discounttvpart.com in wisconsin. I put it in today but still no picture i have back light and sound. Does it need to relearn new part?
          Re: 52" philips tv
          No learning needed, you need to look for surface mounted fuses on the board and use the DC voltmeter, black probe on the chassis, red probe on either end of the fuse, tell us what you read. Take a good close up of the board also and attach the file to the post.
            Re: 52" philips tv
            I found a troubleshooter chart and i am getting power to the ssb board. I changed the t con board is there a way to check the lvds cables?
              Re: 52" philips tv
              Looks like I am in the hunt for a T-Con board also. Any other thoughts?
                Re: 52" philips tv
                Continuity check each pin end to end of cable.
                Did you find/check fuses as budm suggested
                We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                Examples of what is needed
                https://www.badcaps.net/forum/attach...1&d=1290283049
                https://www.badcaps.net/forum/attach...7&d=1280167246
                It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
                  Re: 52" philips tv
                  I suspect you may have multiple problems. I have been working on the same kind of set and here is my $.02. Replaced the main/SSB with one from ShopJimmy (real good place to deal with, BTW) and ended up replacing the power supply too. Came up for a very short time, then dead again. With an assist from a local TV guy that has been the business for a while, tracked it to the T-Con. After looking for a couple of weeks, a T-Con popped up at DiscountTVParts.Com. With all three boards replaced it works. It won't work with the old main board. Did not try it with the old power supply. Not sure the power supply needed to be replaced (all the caps looked pretty much OK and it checked out. But the PS was cheap and now I know it is good...)
                    Re: 52" philips tv
                    i am looking for t-con for philips 52pfl5704d
                      Re: 52" philips tv
                      i was told that the t-con is attached to the panel and it all has to be changed which is a pretty hard job
                        Re: 52" philips tv
                        Who told you that? dont look attached to me?
                        http://www.shopjimmy.com/philips-52pfl5704d/f7
                        Why are you looking for one.
                        Presumably you have the old one - is it attached permanently or not.
                          Re: 52" philips tv
                          very HIGHLY unlikely that the t con is panel attached,definatley not on a 52",you will only see them on 19" and lower panels,possibly 22"-24".
                          troubleshoot the one you have.
                          very likely a t con fuse underated for the amp draw of the tv,they fail sometimes of there own accord.
                          check all fuses
                          if found blown,ohm out the fuse pads if very high resistance then likely a new fuse will bring t con to life again
                          fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                          please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                            Re: 52" philips tv
                            This the same TV we've been talking about here:
                            https://www.badcaps.net/forum/showth...t=21850&page=2
                            T-Con is not attached to panel just cannot find one.
                            Nobody has been able to determine whether that XD component is the fuse or not...
                              Re: 52" philips tv
                              Someone is fixing the TCon board on ebay, so it is fixable
                                Re: 52" philips tv
                                I worked with this TV for awhile.
                                The guy on ebay has a TV repair shop and he's replacing the 2 main IC's on the top of the board with the gray heat sponge and that would be a very difficult job...
                                One came available today on ebay and sold for $120. They come around every now and then.
