RCA 42pA30RQ no picture
    I have this tv RCA 42PA30RQ.Tv has red led turn to green when on., But It has no picture.Power relay click and click couple times.Remove power connector to these Y and X board. No more click and click but power is on.
    Look at Y and X board on the side of tv I found 3 IBGT RJP30E2 shorted On Y board.And 2 IBGT RJH30E2 shorted on X board.
    My question : If I order these expensive Mosfets and replace will fix the tv.Buffer board looks ok.Any body know what cause these Mosfets shorted?
    Re: RCA 42pA30RQ no picture
    I do not see any crack on screen.with power connector unplug from y and X board. I see
    Va and Vs reachs 200v and 60v then goes down to zero.any idea please.
      The FETs fail due to poor design by Samsung. Inadequate heat sinking.
      To test buffer:
      https://www.youtube.com/watch?v=51SZsfH60EY
        Thanks Tom66. I aready order the Fets .8 dollars a piece. Hope they will fix tv.
          You do realise both boards cost less than $40?
          You may want to test buffer as I indicated. Also, the FET drivers may need to be tested. This is why I usually just swap these boards not just the FETs. I see the FETs on eBay for $2~$3 each.
          Remember to use new thermal paste.
            ~2 ~3 eur or dollars? Show me one seller has that cheap on Ebay Please
            Not from HongKong China
              Oh I saw $8 each but it's $0.80? That's a damn good price. Where'd you get them from? Those were mostly China at $2~$3.
                http://www.ebay.com/itm/3pcs-RJH30E2...-/120886916895
                  So $8 each...
                  Just checked the prices, you guys get shafted in the US... in the UK the boards for the PS42B450 (same panel as 42PA30RQ) are £15~£20 each.
                    I like to buy some plasma stuff from England but a bit too far same as Hong Kong. I do want to wait too long( Merchandies must pass custome gate). Nice to know you.
                      Where do you live? Thought this model was US only. Maybe I'm wrong.
                        You are right . USA
                          SJ has heaps of parts, ymains $23, Xmains $29, Y buffer $32 or a complete all boards kit $124 42PA30RQ-K1 S42AX-YB09 panel
                          http://www.shopjimmy.com/catalogsear...lt/?q=42PA30RQ
                          Result RJP30E2 (Equivalent Transistors)
                          Struct Pc Uce Ucesat Ueg Ic Tj Tr Cc Caps
                          1. RJP30E2DPP-M0 N-Channel 360V 1.7V 35A 150 TO220FL
                          2. RJP30E3DPP-M0 N-Channel 360V 1.6V 40A 150 TO220FL
                          3. RJP60D0DPP-M0 N-Channel 600V 1.6V 45A 70 TO220FL
                          4. RJP63F3DPP-M0 N-Channel 630V 1.7V 40A 100 TO220FL
                            I replace the Mosfets on Y and x Sustain board . Add more heatsink to be sure .
                            TV work ok.
                              Glad to hear.
