I got toshiba Satellite L300, its working on battery but when i connect charger it turns off. but when i connect it to laptop without doing it on it charges battery. but without battery it doesn't work with charger.
Toshiba Satellite L300 Power Problem
Re: Toshiba Satellite L300 Power Problem
Probably a Maxim or TI battery management IC acting up. If it charges, the charging circuit is fine and running off battery means the rest of the laptop is not shorted. The battery management IC controls the logic of switching between battery and AC. Look around the battery connector and see if you can find a small (~ .5") square IC labeled Maxim or TI.
Did you remove those to see if they were in fact bad? They look like they've been removed. I've never seen those bad - usually its one of the neighboring mosfets or a shorted cap. If one (or more) of those are bad, they will usually give false reading on other components. The only way to tell for sure is to lift one side of the component and test it that way.
20M on the resistors is in fact 20milliohm... that is likely short
for the A300:try to make short on the backup battery, for about 2-3 seconds, without power or battery on it, then attach the power plug, it should start.Last edited by mihaicozac; 03-14-2011, 09:23 AM.
Originally posted by mattbrad2 View PostProbably a Maxim or TI battery management IC acting up. If it charges, the charging circuit is fine and running off battery means the rest of the laptop is not shorted. The battery management IC controls the logic of switching between battery and AC. Look around the battery connector and see if you can find a small (~ .5") square IC labeled Maxim or TI.
No Maxim or TI IC on my board. Can u please give the location of the IC. Thanks...
When resistor go bad, they raise the resistance, not the opposite.
Take a look at this thread:
https://www.badcaps.net/forum/showthread.php?t=8991
Posts 12 ~ 18.
Originally posted by incradibles View PostI got toshiba Satellite L300, its working on battery but when i connect charger it turns off. but when i connect it to laptop without doing it on it charges battery. but without battery it doesn't work with charger.
same problem to me
i have also toshiba satellite L300 power problem!but i fixed this using 4*330uf capacitor.
unfortunately 20minutes later with charger connected condition i am watching a movie then display gone.like ghost image,then its restart.and no display...!i give to heat gpu but no display.but the laptop running well,both charging light and start light is well,what is the next procedure??please help me sir.
Quote:
same problem to me & but RAM remove then when i connect charger colling Fan runing.
