Toshiba 32AV502RZ
    Toshiba 32AV502RZ
    Hi all, last week I jumped into a thread I thought was for my TV model but it turns out the board in question was a different part number. I was asked to provide the pictures of my board in my own thread so here goes.
    My TV will not turn on, when I push power button or use remote nothing happens, no error code no blinking lights. I took the back cover off and found the main fuse had blown, tried replacing it and as soon as I plugged it back in the new fuse blew again. Following the previous thread I tested the bridge rectifier and it did not pass the test. Using a multimeter on OHM setting I tested points one and 2 on the rectifier and with the leads one way I got no reading and when reversed i got a reading. On points 3 and 4 i get a reading both way the multimeter leads are connected. Are there any other things that I should check or would the bridge rectifier be enough to cause the main fuse to blow? I have attached pictures of both the front and back of the board and the part number.
    Any assistance is greatly appreciated
    Paul
    Re: Toshiba 32AV502RZ
    I seem to remember someone on this forum reporting exactly the same issue with a 32" Toshiba. It turned out to be the surge suppressor TVS1 which had failed.
    You can temporarily remove it and test the TV without it before ordering a replacement to see if it is at fault. Without it, the TV won't have much protection from mains surges, but it will be fine for a 5 minute test.
      It was this thread: https://www.badcaps.net/forum/showthread.php?t=20565
      That Model has shorted TVS. I asked Oconnorp to post new thread since his TV is not the same model or boards.
      @Oconnorp, please post straight shot pictures of the boards with good lights, I can hardly see anything on the pictures, thanks.
        sorry thought these posted over the weekend. Not sure what happened. Here are the pictures front and back. Hopefully better than the other ones
          On the back of the board - primary side there is a largish 8 legged component
          Looks damaged in the picture - is it? Has it got a part number on it that yu can read.
            Use your multimeter on the 200 ohm range to check this device TVS1. You should see no change when probing it if it is good. Do this with the TV unplugged.
              The 8 legged creature looks ok to me, must be a shadow in the picture. I probed the tvs1 as indicated in your picture it reads 0.6 steady when I hold the probes on it.
                0.6 Ohm? That sound like the same problem with the other Toshiba on that thread you were asking the question, the TVS was shorted out. You can remove it, put in the new fuse to test, the TV should come on now
                  While you can remove it for testing, I would not plan on just leaving it out. It is part of the surge protection on the power supply. Leaving that part out would leave your TV more susceptible to lightning/surge damage.
                    Thanks guys I will try removing it tomorrow as a test and let you know how I make out.
                      Removed tvs1 and tv will now power on. Thanks. What is next step?
                      Thanks again
                        Thanks again
                        Replace the TVS with one such as this device.
                        http://www.digikey.com/product-detai...PCT-ND/2776400
                        Check the lead diameter (1.3mm max) will fit the hole.
                          Or this one from Mouser:
                          Surge protection: BI-DIRCETIONAL TVS
                          Vishay:
                          http://www.mouser.com/ProductDetail/...dcLaMwTMwps%3d
                          Which was used in the other TOSHIBA on another post.
                          I would go with DIGIKEY since they will do USPS shipping at low cost.
