More bad news for those with APs with Wi-Fi Protected Setup
    http://www.myce.com/news/researcher-...e-force-56550/ (also has several links)
    Should I write an article named "The Dangers Of Wi-Fi Protected Setup"?
    Re: More bad news for those with APs with Wi-Fi Protected Setup
    I turn off WPS every chance I get. It didn't make connecting to routers any easier. At least 4 hours is better than WEP... for now.
    sig files are for morons
      I never use WPS anyway. I thought it was pointless. (To me, anyhow.)
      It is on by default on my Linksys WRT54Gv8 router on its original firmware (before I installed DD-WRT on it). I found it annoying and just turned it off after I factory reset the router, which was rare.
      Recovering a BEFSR41 v1 and v2 router from solid red DIAG Light
      I have two v2s and one v1.
      I am still looking at these boards nearly every day.
      What I'm doing: Planning an upgrade of my mining setup from Block Erupters to Red Furys. Though, if the Block Erupters don't sell, I will keep using them for a while.
        most people are too stupid to use it, its can be a bit pita imo
        I use PFSense, so, the issue is moot for my network
        when I setup a customers net I always disable it, it just confuses things
          I don't even have a new enough wireless router that has it.
          I make up my WPA keys myself I don't need an idiot button .
            Turning on Enterprise security disables Wi-Fi Protected Setup (a few routers have a inbuilt RADIUS server), but that comes at the expense of certain devices not being able to connect with Enterpise security, particularly media devices.
