vizio e370vl no power
    I need help with a zizio e370vl .It has a yellow power indicator that flashes to white and back to yellow .
    I have removed and checked the esr on all caps all were below .1 ohm .
    I have removed and checked all of the large transistors and fets .
    I am unable to find data sheets for what appear power controller chips that have the following markins
    as324am mp1008es mps 0930
    ta2be 742mr5yb
    The power board model # is dps-192ap
    I have attacheds some picks of the board there no aereas of the board that show evidence of over heating .
    Re: vizio e370vl no power
    Your pics currently need some attention.
      I am unable to upload pics I get a missing security tag error .
        Pictures are too large. Maximum size is 2000 pixels in either dimension.
        PlainBill
          I also have the same LCD TV but my yellow logo light switches to white when the power button is pressed but no picture. How can I figure out which component is bad?
            Start by posting pictures of the insides of the set. Do you have a digital multimeter?
              E370VL I have replaced the power supply and the EEPROM on the main board and still i am only getting the amber light it does not change color to white? On the connector from the power supply to the main board the only voltage is 5v, no 12 going to the main board, I have checked fuses they are good! what are voltages should i read on the EEPROM and on what pins?
                As Tom said above your post, start by posting pictures of the insides of the set. Do you have a digital multimeter? Vizio's are infamous for bad voltage regulators on the main board. Post some pics and read through this.
                https://www.badcaps.net/forum/showthread.php?t=22231
