2007 Samsung LN-S4095D won't power on.
    I bought my Samsung lcd in March 2007 which means it was probably manufactured in 2006. I was watching Netflix when the tv flickered on and off as if it was being reset during a power brown out. There were brief artifacts on the screen and my home theater system displayed the HDCP ERROR message. Sound kept working, but the video wasn't coming back. It did this 2 or 3 more times over the next 5 minutes until it just wouldn't power back on anymore.
    When pressing the power button on the tv, nothing happened. When pressing power on the remote, the light next to the power button would blink on the tv but again it wouldn't turn on.
    After searching online I saw the common problem being the capacitors. Once I removed the cover and exposed the power board, I couldn't see any apparent issues with the capacitors. No bulging, leaking, etc. There was one capacitor that had black smearing on the top that looked like magic marker, but I remember seeing that can be leakage. So, I removed it. Upon close inspection of the capacitor, there is no swelling or damage to the top, I'm wondering if it was drawn on. I marked that capacitor in the first pic.
    In the second pic, focusing on the upper right corner of the board which is a common problem area in other Samsung tvs, the caps seem ok, but there is one cap that seems to have a different substance on its surface than the one directly near it. They are wrapped in some sort of sleeve, so I can't tell what exactly they are. The only marking it has is that it is rated at 105 C. Could that be a problem as well?
    Re: 2007 Samsung LN-S4095D won't power on.
    That is likely black felt marker from the factory.
    If it is marked LM852 on the board, "L" is usually an inductor and they rarely go bad.
    http://en.wikipedia.org/wiki/Electro...e_designations
    http://en.wikipedia.org/wiki/Inductor
    Do you have a multimeter and know how to measure DC voltage? If yes, what are the DC voltages on the two connectors in the corner? List them like so,
    legend-silkscreen my reading
    pin GND = 0
    pin 5V SB = 5.034
    --- begin sig file ---
    --- end sig file ---
      In the photo that you have the one on left which I am going to say in #1 it looks like this may have cap pop it top
      If I was working on this set and had it 5 years already I would check ALL CAPS with a ESR cap tester if you do not have one I would replace
      ALL of the caps on that board with FC type caps
      If you run this TV set like I run mine it ON for at least 12 to 14 hours a day and some time more than that
      There is not that many caps on this board
      http://www.digikey.com/product-searc...luminum/131081
      In the search pick FC Type
      Series = FC
      Manufacturer
      Capacitance = The value that you want
      Voltage Rating = The value that you want
      Tolerance
      Lifetime @ Temp.
      Operating Temperature = This will be 105
      Features = General Purpose
      Ripple Current
      ESR (Equivalent Series Resistance)
      Impedance
      Mounting Type = Through Hole
      Package / Case
      Size / Dimension = The value that you want if you know the size
      Height - Seated (Max) = The value that you want if you know the size
      Lead Spacing
      Surface Mount Land Size
      Packaging
      I hope this helps
      9 PC LCD Monitor
      6 LCD Flat Screen TV
      1 Dell Mother Board
      15 Computer Power Supply
      All of these had CAPs POOF
        Can I see the whole back side of the TV to see how all the boards are connected together?
        On the first picture, there is a small connector on the top left of the board, next to it there is label indicating the function of each pin. Can I see that picture?
        On CN801, there is a pin with 'ON/OFF', can you take the DC voltage reading when the TV is off and when the TV is turn on by the power switch, I want to see if the voltage is toggling at that ON/OFF pin.
          @sam_sam_sam
          Capxon makes terrible quality caps and while I would agree with your suggestion to recap in general (after there is some evidence the caps are at fault), the suggestion of using FC may not meet the original caps' ESR.
          Panasonic makes FM/FR which has better ripple and ESR characteristics compared to FC.
