Thank you to the guys at HEGE supporting Badcaps HEGE HEGE DEX Chart
TSP 51125 fail to give 5.0voltage
    Mother board :
    6050A2170401-MB-A03
    Error :
    Dead no power LED ,no HHD spinning or any POST
    Troubleshooted
    Charger IC (BQ24721C)is ok giving out 10.9v with battery and 14.6Vwith
    Adaptor charger
    Obsevation:
    I obseved 10.9 along TSP5117 but Missing 5V to power TSP 5117,ADP 3208 and other 5v
    Please give me hand on this , I need to power on this Machine
    Thanks in advance
    Re: TSP 51125 fail to give 5.0voltage
    What laptop is it out of - please put that in the thread title
      Toshiba Satellite L300
        here is a link to the schematic
        http://lqv77.com/download/652/
          thanks Selldoor
          I got the LINK
          What i have on TPS 51125 is only 3.3 voltage which is good
          but on pin 20 and pin21 0Voltage instead of 5 voltage
          where is the problem?
            thanks for all , now i will be going out till tomorrow
              i have the same situation with Toshiba A300. no 5v on TSP51125, only 3.3v
              i replaced TSP51125 and still not working
              thanks.
                If you'd like me to take any readings from a working L300 GL960 board, feel free to ask. Just as long as they're not risky (i.e individual pins on QFN chips that aren't connected to nearby components)
                Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                  i'm having the same situation here, i have 3.3v but no 5v. TPS51125, satelite c665. Still working on it, if i solve i'll let you know. But if you allready solved the problem please answer the post..
                    I checked datasheet of tps51125. To enable outputs, pin 1 and 6 should be connected to ground by 130k resistors. In my case, EC is driving these pins through a swithcing circuit. I disconnected a transistor, it is working now. But that means i have a faulty EC.
                      What is EC ? how to handle ec
                        EC is the embedded controller
                        -David VanHorn
                          Same issue with toshiba A300, I don't get the 5V at L22.
                          Replaced U27 with no luck.
                          System powers on and off soon after. Already replaced nec tokin capacitor.
                          If I disconnect Q34 I get the 5V but it powers off again.
                          Also I replaced U29 kbc but same issue.
                          Schematic provided.
                          Any help appreciated.
                            Checked for short on that rail?
                            -David VanHorn
                              I get higher than 15kohm at that rail - seems normal
                                some times ic fault and some time 5v line having shortg in any resistncs
