TRIAC BTA12 - Your thoughts, Please!!!
    Have a TRIAC, ID: BTA12. Here is the URL for the datasheet:
    http://www.datasheetcatalog.com/data...A12-600C.shtml
    The package is a TO-220AB Insulated, in other words it is packaged the same way as most HOTs. The only difference between HOTs and TRIACS is that , leg 1 from the left is Anode 1, leg 2, the middle leg is Anode 2, and leg 3 is the Gate.
    On connecting a digital multimeter regardless of polarity between Anode 1 and Gate, the resistance is ~45 Ohms.
    There is no reading between Anode 2 and Gate, infinite resistance, regardless of polarity.
    Also, no reading between Anode 1 and Anode 2 regardless of polarity.
    Now, if either positive or negative polarity is applied to Anode 1 and Anode 2 and the Gate is shorted to Anode 2, the multimeter reads ~45 Ohms.
    Upon disconnecting the Gate from Anode 2, again the reading becomes infinite while the leads of the multimeter are in contact with Anode 1 and Anode 2.
    The question is:
    Should the reading continue to be ~45 Ohms after disconnecting the Gate from Anode 2, at least this what the theory tells me on testing Triacs, ( the resistance should continue , in this case, to be ~45 Ohms, provided the multimeter leads are in contact the Anode 1 and Anode 2) or
    is the Triac faulty? and the reasons why.
    Sincerely
    Re: TRIAC BTA12 - Your thoughts, Please!!!
    http://www.repairfaq.org/sam/semitest.htm
      Hello kc8adu,
      Have a read at this article: http://www.datasheetcatalog.com/data...A12-600C.shtml
      and compare the info with respect to the info given on testing Triacs in the URL you provided.
      Sincerely
