Megmeet mlt666t board
    Hi all i have a technika 32-56 lcd tv set,it has power issues,switches on once the not again,so i purchased another power board (mlt666t) of a well know auction site and guess what it still does not switch on not even a flicker,the boards i are both the same part number,but the date is different,would this make a difference ?
    REV:1.2a 2008.11.06 or-
    REV:1.2a 2008.09.02
    Re: Megmeet mlt666t board
    Probably a date of manufacturer.
    Do you have a multimeter? - check PSU outputs are stable including standby voltage.
      Ok,very annoying though,seller got brilliant feedback and even in the listing its been apparently tested,-what else could it be ???
        Uh, no-one (well almost no-one) test the boards on eBay.
        Have you actually CHECKED the power board to find out if the original was bad before replacing it? Otherwise, you may be chasing a wild goose.
          Hold my hands up I did not check the original board,I had to flick the on/off switch until the set came on,then did not power on again,hence why I bought another one.
          With this new one I'm not get light or naff all,I'm only a newbee and wouldn't know how to test unless you could tell me the basics,then i will test both boards,all I have is a multimeter though.
            Well I would be considering main board TBH with those symptoms.
            Checking power board outputs: locate each connector, multimeter in 20VDC range for voltages up to approx 18V, and in 200VDC range for 24V/33V outputs.
            Red probe on each pin of each connector, black probe on chassis. Note reading down and compare to labelling, if available. Test in several states: standby, working first time, second standby, failing second time.
              Hi when you say check each connector does this included the two pin power lead one ?
                Not presently, though checking your input AC voltage can also be a good check just as a general thing to rule out. Use the 750VAC range.
                Also do NOT test any outputs marked HIGH VOLTAGE e.g. if board has inverter built in. Typically white/pink/sky-blue wires.
