Badcaps Forums
Badcaps Forums (http://www.badcaps.net/forum/index.php)
-   Troubleshooting Computer Displays (http://www.badcaps.net/forum/forumdisplay.php?f=30)
-   -   Open frame lcd monitors 19" - in gaming machine Novomatic (http://www.badcaps.net/forum/showthread.php?t=7307)
8832 06-25-2009 05:44 AM
I repair 10-20 this open frame lcd per day. 95% problems is bad capacitors Evercon LE, Jackcon low esr. This lcd icluded vga-video PCB Winmate types R7X410, R5U210, R7X120,*Z5U120 and other. In this pcb used low cost taiwan capacitors with live time 1000hours/temperature 105 celsius. In nonstop function this caps blow/damage after cca 1.5-2years, or if using noname caps (brand "S.Y" is live 5-7months).
In repair this monitors i use caps Teapo SY lifetime 5000hours/105 celsius. After repair monitor with dis caps livetime 6-7years.
4% problems with monitors is bad smd fuse 3.15A/2A orj broken secondary coil in light transformators in pcb light invertet.
1% problems is bad lcd panels AU Optronics model M190EG01 M190EN03 or Chimei M190E2 or M190E3 - short circuit in DC-DC converter - short ceramic smd caps and after bad fuse.
EGuevarae 06-25-2009 11:09 PM
Re: Open frame lcd monitors 19" - in gaming machine Novomatic
Where do you work to have that flow of units?
dmbj 06-26-2009 05:56 AM
He must work in a slot machine repair place. Man I could use a few of those monitors, especially if the sync to 15.75Khz :)
EGuevarae 06-26-2009 09:38 PM
When I was like twelve, I used to work repairing arcade control boards (control as in joystick, buttons and the like, not motherboards/main), changing boards and power supplies.They were the usual CRT repair/exchange, but I guess my idea of that kind of shops stayed like that in mi mind. Now that you mention the slot machine repair shop, it makes sense. :noob:
dmbj 06-27-2009 07:59 AM
You repaired control panels.
I still to this day repair, restore, un-convert back to original, and collect arcade games. I have 15 mint restored machines in my home and currently have 5 or 6 out in the garage that i am repairing for other people. A lot of people (not me) like the lcd's in there games. and those open frame lcd's are about $450 with the mounting kit from happ controls. For the most part I stick with old school Electohome and Wells Gardner monitor chassis, recap them, swap out the crt with ones i get out of old tv sets. All of my friends know to stop and pickup 19" tv sets out of the trash when they see them. It it turns out to be an non compatible tube i can still just dump it again.
EGuevarae 06-27-2009 12:18 PM
Sorry for mistaking the name. That's why I put a description, as things are lost in translation Spanish->English.
Back then where I used to live we had the regular arcade machines, but most of the machines were self-made arcade cabinets with (depending on the era) an Atari 2600, Coleco Vision, Atari 5200, NES, Super NES and the last project was a custom system developed in Mexico called FELEC, that was similar to a SNES. What people do sometimes this days, open an xbox/xbox360 controller, solder in switches and install it in cabinets inside an arcade cabinet for the so called MAME cabinets, we did 20 years ago, and for a living. The use of the systems was limited (like the game machines here in USA), you need permits and a lot of requisites were to be present for you to get a license to work this kind of "arcades" . Then they removed ALL the requisites, everyone got some machines, and they killed the business. Only the largest owners survived (Walmart-like killing small business). I still maintained some cabinets, but I lost interest.
But I'll enjoy working on a place like that (I just applied for a job as Slot Technician in a near Casino) a few days ago.
8832 07-02-2009 05:41 AM
This lcd is original components in gaming machine in european locality types "Magic Games II", "Video lotery terminal", "Video network terminal" , "Game Pallace III" and other. This multi game machines used PC standard IBM pentium-higher and used system dual SVGA grafic card N-vidia-multiscreen -2 lcd in cabinet and main lcd used capacity touchscreen 3M/Elotouch. This machines is product AGI Austrin gaming industries - Novomatic group and building is in AGI and EDP-czech republic.
There Open frame lcd is constructing to standard lcd panel, video pcb Winmate with osd processor Symos and video processor realtec family RTD2023 and pcb light inverter for 4 neon bulbs in the lcd panel backlight.
Power is central 12V DC to 6.3mm Jack.
Olds family machines Magic games I used 19" CRT SVGA chasis Pentranic.
slotexpres 05-02-2011 05:22 PM
THANKS!!!!!!!!!!!!!!!!
This post is explain to me exactly what is wrong with my monitor, thanks again
Also I have problem with power supply on Novomatic FV623 (usual 5V line). Did you maybe have any similar tip? After day or two machines shut off and all diodes on main board lit and when I wont to start machine just I have strange sound from speaker. Thanks again.
smason 05-02-2011 05:51 PM
In a previous life I serviced standalone word processors (before PCs became available)
They used either Electrohome or Motorola monochrome open frame monitors.
The Electrohomes were solid, had the odd bad HOT, the Motorolas had chronic bad solder on one of the transformers. Ahh the good old days.
Other techs would schlep a new monitor out to the client site, I'd take a soldering iron and a few transistors.
The power supplies were Way over-capable. Torodial transformers big caps and linear regulators, almost never failed.
Karlos007 03-16-2012 04:46 PM
Hi, I have repaired many theese monitors replacing bad capacitors, mosfets, dc/dc convertesr etc. But some of them especially these with Z5U120 board have bad SyncMOS chip. I have SM89516C25j PLCC44 blank chips. Also have BeeProg and Wellon programmers but I am not able to read the content of the chip to use it for programming the blank one. Probably it is protected from reading. And my Question is, wheather is there a possibility to gain somewhere the software for SyncMOS chip in Z5U120 board or not. Thanks for reply. B.R. Karel
Scenic 03-16-2012 05:45 PM
Try to read the contents from one of a working Z5U120 board?
Or look up the datasheet of the SyncMOS chip (EEPROM ?) to see if it has any read/write protection pins.
kondy73 04-03-2012 09:19 AM
Z5U120 we have, but all Syncmos cpu on this version is locked against reading firmware.
Did you meet with the problem of fluctuations in the 1.8V on the board R7X410 and R5U210?
How to solve it?
kondy73 04-03-2012 09:26 AM
This Syncmos is clone of Intel's CPU MCS-52 family. External EEPROM not solved problem if is damaged firmware in CPU.
And if I know where, if the flash memory is locked against reading, so do not do anything with it ...
miradzy 05-14-2014 11:13 AM
I am Michael, I have a couple of novomatic 19'' touchscreen boards : R5UV120
Can anyone fix them fo
miradzy 05-14-2014 11:14 AM
I mean repair them for me.
stj 05-14-2014 03:23 PM
post a foto, i'v only seem 3m and Elo boards.
btw, i have extensive schematics & rom/pal dumps for older arcade stuff.
miradzy 05-15-2014 09:25 AM
1 Attachment(s)
Attachment 86455
stj 05-15-2014 02:15 PM
is that a touchscreen controller?
i cant see any analog parts?
chchtono 10-15-2014 09:22 PM
Could you take a photo about monitor's resolution?
Topcat 10-16-2014 10:00 PM
Last Activity: 09-26-2009 03:43 PM
I wouldn't count on that one...
