Badcaps Forums
Badcaps Forums (http://www.badcaps.net/forum/index.php)
-   Troubleshooting TVs and Video Sources (http://www.badcaps.net/forum/forumdisplay.php?f=31)
-   -   37" Vizio VX37L Keeps Turning off (http://www.badcaps.net/forum/showthread.php?t=27089)
tieny 03-12-2013 10:18 PM
I have a 37" vizio VX37L that keeps turning itself off when I turn it on.
So plugged in, with vizio amber light in front, I press the power button, amber light turns white and the tv turns on. About 3 seconds laters the TV turns off and the vizio led in front goes back to amber.
I'm measuring 4.63V on the PS_ON, when it turns on.
I'll post up photos of the main board, and info on the regulators in a bit.
tieny 03-13-2013 09:22 AM
Re: 37" Vizio VX37L Keeps Turning off
1 Attachment(s)
So I found a total of 13 regulators on the main board.
U6
GI8L 17-33L
0v 3.29v 5.21v
U4
GI8L 17-33L
0v 3.31v 5.21v
U8
GI8L 17-33L
0v 3.29v 5.21v
U9
GH3L 17-18L
0v 1.82v 3.29v
U10
GH3L 17-18L
0v 1.82v 3.29v
U5
AMC1117
0.70v 1.95v 3.31v
U16
GF2L 17-25L
0v 2.53v 5.20v
U7
GH3L 17-18L
0v 1.81v 3.29v
U18
AMC1117
0.25v 1.50v 3.29v
DU4
AMC1117
0v 0.13v 1.04v
DU1
7805CT
0.67v 0v 0v
DU3
GF2L 17-25L
0v 0v 0.44v
DU2
GJ8L 17-33L
0v 0.39V 0.43V
How do those readings look?
Also I'm getting 4.63V for PS_ON, is that high? Isn't it suppose to be 3.3v? If it is, would the main board or power supply be causing it?
budm 03-13-2013 09:28 AM
Are those voltages tested with the TV is turn on or in standby mode?
"DU4
AMC1117
0v 0.13v 1.04v
DU1
7805CT
0.67v 0v 0v
DU3
GF2L 17-25L
0v 0v 0.44v
DU2
GJ8L 17-33L
0v 0.39V 0.43V"
These do not look right if the TV is ON.
PS_ON =>3V
tieny 03-13-2013 09:45 AM
Those readings are during standby.
With the TV turned on the readings are:
DU4
AMC1117
0v 1.26v 3.36v
DU1
7805CT
12.06v 0v 5.05v
DU3
GF2L 17-25L
0v 2.51v 5.10v
DU2
GJ8L 17-33L
0v 3.30V 5.10V
tieny 03-13-2013 10:17 PM
I think those readings are good.... I don't know anything about DU1, 7805CT but I'm going with my gut feeling that its not the problem... ugh another unsolvable one..
I've been searching on google for a similar problem and found this
http://www.justanswer.com/tv-repair/...ue-screen.html
Its stating that this problem is caused by a bad LCD panel?? Is that even accurate at all?
budm 03-13-2013 10:44 PM
It is just the 5V regulator. So the voltage readings when TV is ON are also OK.
tom66 03-14-2013 02:43 AM
Disconnect the side button board if possible and see if it still turns off.
tieny 03-14-2013 07:45 AM
I disconnected the side button board and turned on the tv with the remote but the tv is still turning off.
tieny 03-14-2013 07:50 PM
I noticed a blue LED diode on one of the inverter board that lights up bright and slowly fades off when the TV turns on. I've never seen this before, is it possibly indicating a problem with the inverter board, or a possibly a bad ccfl lamp? That would explain the reason for assuming a bad lcd panel from the link i put in post #5.
tieny 03-16-2013 11:34 AM
Dissassembled everything, checked CCFLs and they all seem good and working...
The problem again with this TV:
TV powers on fine, shows a blue screen with the no signal message, and then shuts off. While the TV is on, I cannot get the OSD menu open or change any inputs on the tv or with the remote. It just only says "No Signal" (With this fact I'll assume a bad main board...?)
The guy I got it from said itll only stay on if theres a source hooked on it and itll shut off to save power if theres no input. (I thought that was just BS) but he hooked on the hdmi and actually got it to play a picture, so i bought it.
So I tried hooking on both hdmi inputs but the tv won't even stay on. I have no idea what the hell the guy did...
But if this is in fact a bad lcd panel like "justanswers" stated then I guess itll going to be recycled, unless anyone else has an idea.
budm 03-16-2013 06:09 PM
It does sound like bad main board if you cannot control it with the remote or buttons.
tieny 03-20-2013 08:06 AM
Bleh, main board problems... :noob:
Guess this one is a bust.
So I'm parting this one out on ebay. Even the main board, maybe someone else can get it and fix it for cheaper. If anyone needs any parts from a Vizio VX37L just let me know.
tieny 03-23-2013 12:19 PM
I just found the problem.
It seems with these vizio tv's whenever its on the RGB input, it will shut off when there is no signal input for it. Took me buying another main board to figure this out...
I found out that it will take about 15 seconds until the OSD menu and input menu will be accessible. However since it was on the RGB input it would shut off before the 15 seconds and thus i wasnt able to change the input at all. So I hooked on my laptop allowing the TV to stay on waited until i can open the menu and then was able to change the input. So about 15 seconds after the TV is turned on it will work perfectly, opening and closing the menus.
Using the new main board as soon as I turn on the TV I can access the menu immediately so this the main board is definitely at fault. I don't know the exact component causing the fault but at least the TV is perfectly usable with the old main board.
budm 03-23-2013 04:31 PM
Oh but I thought you have no control at all from remote or buttons, and also does not work with HDMI source when you tried it:
"but he hooked on the hdmi and actually got it to play a picture, so i bought it. So I tried hooking on both hdmi inputs but the tv won't even stay on. I have no idea what the hell the guy did"
Live and learn.
tieny 03-23-2013 06:32 PM
Thats true I didn't have any control at all from remote or button. It was only until the TV "warms up" after it turns on. But since it was initially on RGB it would always shut off before "warming up." and I wasn't able to switch to any other inputs. Thus the problem where itll be stuck with this loop...
I'm still not sure what the previous owner did. I swore I saw that hdmi cable, or maybe I was crazy and it was actually VGA. O.o
litenan 09-11-2013 03:44 PM
Thanks tieny, I was having the same shutdown problem with my vizio, was thinking on just trashing it. I had let someone borrow it for a few months and when I got it back it was doing just what you described. She must have hit the rgb button on the remote and figured it was broke. Anyway thank you, thank you, thank you fer that tip.
dymondgirl 07-03-2014 08:05 AM
Thanks tieny. I'm having the same exact issue...my daughter kept trying to change the input to get the dvd player to work and in the process, must have hit the rgb button. I can't get the tv to stay on long enough to get to the menu to change the input. How exactly did you do it by connecting to the laptop/computer?
stj 07-03-2014 08:29 AM
i think RGB is an error by the guy who posted it.
i think it's refering to the VGA connector.
dymondgirl 07-04-2014 05:03 PM
stj - thanks. connected a VGA connector from tv to the laptop and it allowed me to get to the input menu and change. this worked - tv back on!
